As the title says, Listary randomly crashes. It seems to happen after the system and Listary has been running for some time. It shows this image:
We are at version 6.3.0.51
It’s useless to make error reports for your very old version.
Listary download page still lists 6.2.0.42
Checking for updates says 6.2.0.42 is the most recent version of Listary
This forum says 6.3.0 is beta
What’s the problem to try the actual version ?
I for one upon seeing the problems that users faced with 6.3 release decided to wait with the update. Maybe those complaints were regarding some completely new feature but I got a feeling that something that used to work was now broken.
Thus maybe a tone could be a bit friendlier and understanding when answering.
I’m only a user as you.
If I want to report problems and there is an easy way to first check the newest version,
I will always do that.
This prevents myself useless searching for solutions of already fixed bugs
and reduces the load of developers, so they can concentrate on open items.
Btw. I don’t see anything unfriendly in my answers.
Windows 11 Home x64 Version 22H2 (OS Build 22621.2361)
Listary Pro 6.3.0.51
Spending time and resources to do so, especially a beta version. Also,
It’s not useless, as the bug may still be present on newer versions
