Steps to Reproduce
Double tap control or right click on the tray icon and select Open Launcher
Expected Result
Listary search window opens
Actual Result
Nothing
Windows Version
Windows 10 Pro 22H2 Build 19045.6466
Listary Version
6.3.6.99 Beta
Additional Information
Just stopped working at some point in the last few weeks, not sure why
I’m having the exact same problem with the Launcher (the secondary, huge file search thing works fine). Same Listary beta (6.3.6.99 beta), but different Windows.
I’m on Windows 11 Pro 25H2, 26200.8246.
After some further troubleshooting I have determined that the launcher is in fact opening but it is being rendered off screen. If I double tap control and blindly type something and hit enter it will open that thing (e.g. if I type in the name of a known document). I went to Options > General > Launcher Position > Reset and that fixed it
