Hi, fuzzy navigation will be replaced with something more powerful and easy to use in the next version. Here is part of the new feature: http://discussions.listary.com/discussion/1313
That is good to know, thank you very much!
Seems like a nice implementation, can’t wait to test it.
我搜索qqjt(千千静听),因为新版有了Launch applications功能,不管我执行了多少次千千静听,可它总不能自动排到第一位,列表前边都是app目录中的程序,这是不是一个BUG啊?
来张截图?
Very very nice : ) I was using Launchy before as a program launcher but Listary is much faster when indexing and it’s better for me to have less autorun programs.
I would though very much like to have the small toolbar option extended to include the app launcher if that is at all possible.
这是打入qqjt关键子后的结果,系统将启动程序放到了最前。
!(http://uploadpie.com/2irIw)
这才是我要启动的程序,新版以前,这个是排到最前头的,这才是我日常使用的习惯
!(http://uploadpie.com/mEWFm)
“启动程序”里面没有H:\tools\快速启动\千千静听这一项?这个不应该啊……确定这个快捷方式存在么?
没有啊,启动程序里有H:\TOOLS\工具\ 这一项。
这个快捷方式肯定存在的,一直就是这么用的啊!如果把启动程序中:H:\TOOLS\工具\ 这一项删除,那么就正常了!
你得把H:\tools\快速启动\加到启动程序里才行啊
晕倒,我觉得,启动程序不应该凌驾于使用习惯之上啊,比如这个千千静听,我都用qqjt这个关键字启动不下30次了,所以在使用习惯上他应该优先度最高才对呀!
是啊,不过这个功能只搜索你在“选项-启动程序”中列出的文件夹。
那好吧,只好不去用这功能了,不然每次都排前面去会很烦,启动程序的优先度应该低于用户习惯、工程、命令 才对呀!
赞成啊,现在在非文件夹模式下要搜个project都难,严重影响了工作效率,只能把选项中的launch app里的勾全部去掉,等于禁用了launch app功能
I found Launch applications in some escenarios very annoying.
I suggest you add an option to enable/disable this feature with a key.
ex: Pressing “:” turn on/off launch apps.
What about adding a list for launch applications to start. This way you can arrange them as you like and add-remove what you don’t need. So, something like the project list, but then adding apps you liek to start quickly, without searching for it.
Launch applications will be refined in the next version.
新版已经做出相应改进,欢迎测试。下载链接见最上。
Please give the new version (v1480) a try. Download links are listed on top of this page.
Channing said:
@aquaqu
@johnnyjian新版已经做出相应改进,欢迎测试。下载链接见最上。
试用过了,确实比之前方便多了。
一个建议,在非文件夹模式下唤出listary会记录上一次的模式,但是如果我不输入任何东西的话,输入框是一片空白,这时候我就不知道现在正处于什么模式,希望有一些标识来显示目前处于什么模式,譬如,以灰字显示“Launch Apps”或者“Search”。
PS:希望尽快解决Launch Apps闪烁的问题。
有新版本了,,,可惜没有更新匹配路径检索。。。不过能有更新就是好事,不知道什么时候增加路径匹配啊。过几天就过年了,Channing 你回国内过春节吗?
报bug:发现全用win+G热键时,因为是win7系统,且启用了系统自带的桌面小工具,所以,按这个键的话就是把桌面小工具置到当前显示。。。
不过如果不用win+G,只用win+s也不影响使用,现在在列表和启动程序间切换非常方便好用。
