I really like this feature in listary5, it’s quite convinient. but I can’t find this feature in beta6.0.2.14. has it been removed permanently or we can get the same function in another way? thanks a lot.
This function has been integrated into File Search -> Filters.
I tried File Search -> Filters, but it’s not the same as keyword->Folder feature.
e.g. I set a keyword MX, when I enter MX in listary 5, d:\working\MX\ will be the first match and I can open that folder directly by hitting Enter. but I in listary 6 beta version, current match result come in front of d:\working\MX\, I can’t use Enter to open it, I have to use ctrl+N to open the folder, which is not that convinient! I hope shortcut-folder will be the first result if I already set a keyword for it, then other search results.
It’s unusual. This used to be a problem and was reported by some users, but should’ve been solved. I even tested on several folders to confirm it before my first post.
I notice that there is a new beta version, I will give it try, if this still happens on my side, I will report it. thanks for your reply.
我咋用英文问的问题呢?抱歉,还是说中文,忘记是中文论坛了。
我升级到了最新的beta版(6.0.5.16)这个问题还是老样子,我特意录了下屏,跟listary5里的行为还是不一样。
作为对比,我也录制了listary5的表现,如下
双击 Ctrl 激活之后呢?
双击ctrl激活之后是ok的,但是会不方便,我觉得listary5里的这个功能超级好使,不会以后都要双击ctrl之后才可以用吧? 个人觉得多了一步操作,会慢,希望可以考虑像listary5里的那样!
了解,之后会做成一致。
下载试用6.0.5.16后,发现此功能已经加上了,但是在某些情况下,预设的关键字搜索的结果还是不会被列在第一位。猜测跟内部优先级排序算法有关,如果是这样,可以考虑把对应关键字对应的优先级设置的很高。不知道其他小伙伴是否有类似的问题。发现此功能可用后,已经切换到listary6上了,感谢作者的努力。希望listary6正式版早日发布。
