When trying to use the popup menu in Filezilla 3, Listary will change the path for the first opened tab, instead of the current tab. Would it be possible to fix this?
Thank you!
Thank you!
Hello Nozavi,
I’m sorry that this is not easy to fix currently. I’ll look more into it after finishing Listary 4.
