Is there any way to use Listary to rename a file? If not, please implement this ASAP! It’s extremely useful.
Thanks,
Steve
Thanks,
Steve
Hi All,
I’ve found a way to rename a file. See the attached image to configure a custom action that will do it.
In case the above image is blurry:
Hotkey:
Keyword: ren
Path: powershell.exe
Parameter: Rename-Item -Path “{action_path}” –NewName ”{query}”
[x] Silent
[ ] Run as Administrator
To invoke it, let’s say that you have a file named “velleman1992.pdf.” This is a philosophy journal article that I downloaded. I like to rename such files so that I can tell what they are by their filenames. The name of the journal article is, “What Happens When Someone Acts?”
So, to find and rename it using Listary, type:
Ctrl-Ctrl
velleman1992
(right-arrow)
ren What Happens When Someone Acts-Velleman.pdf
Boom!
Done.
I hope this helps someone.
Thanks,
Steve
