Thanks for the prompt response, Leroy. However, I click left, right and middle mouse button and nothing happens. I use Directory Opus and checked the settings in this program and turned off any specific function involving middle mouse button.
Thanks for the reply. It seems that the shortcut works. But it is still a new shortcut. Do you by any chance know what the function is of the icon on the far right of the window that appears when you press CTRL twice? I have not found out what it does because it is always greyed out in my situation. In version 5 here you could access the favorites ats in one go.
Having this same issue, i want to press ctrl twice then click on the 3 dots, just like in the last version. this was removed for some reason? I don’t want to memorize a new hotkey, or middle click on the folder. I want the old functionality back. It was great as is!
I thing you have to check the settings to ensure these features are enabled. Make sure you’re using the latest version of Listary Pro by checking for and installing any updates, Then a simple restart of the application can resolve display issues, so try closing and reopening Listary.
I hope this will help you,
Thanks
No such feature in the settings to enable in v6 or am I missing something?
I loved the feature in v5, having those 3 icons when you 'd double click CTRL and it’s now gone in v6.
Can you bring it back please,
Thanks
