Thank you very much first of all. It seems to work. Windows Explorer is opened by default. However, I use a different file manager called Freecommander. Although this opens, it takes over the previously selected directory, not the one I entered in the Working directory field, namely D:\X-Plane 12. Do you recognize a mistake in my settings? I can’t get any further. I would be very happy for help.
If you use a third-party file manager, you may need to pass the path via command line parameters. I suggest you fill in D:\X-Plane 12 in “Parameter” and leave “Working directory” empty.
In addition, I also referred to the advanced usage of freecommander. If it still doesn’t work, you may need to use specific parameters, such as /C /L="D:\X-Plane 12", etc. For details, you can check this website Command line parameters .
However, considering the compatibility and update issues of third-party tools, there may still be problems during use. We will improve Listary as much as possible.
