How to clear history?
I’m using Listary Pro 6.2.0.42. I’d like to clear the search history that shows up when I start a search. There’s a post from 2016 that says there’s a Clean History button in Options but I can’t find it. Is there any way to do this?
Probably the same issue. I noticed today that in my search results there are unwanted items from previous indexed folders that I don’t have in indexing settings since months. I have managed to remove them by setting them in exclusion list. Not a clean way, I suppose.
There is
C:\Users\yourname\AppData\Roaming\Listary\UserProfile\Settings\SearchHistory.json
Delete it
Done, thanks. Just for future reference, you need to close Listary first, otherwise the same history content appears again.
It’s a bit “weird” having items in history if relative paths are not indexed anymore. Or not?
No, it’s sometimes useful, as the disk which is related to such a search
my become available at a later time.
This option is missing, please return it.
