Can the icon in the tray bar be black and white?
The colorful icon seems strange like the picture above.
I have tried to change it with exescope:
but all the icons are changed except the one in tray bar.
This is the icon in start menu after changing:
horst
I see the problem with your other tray cons, they are missing the colour.
It’s not possible to change the tray icon at the moment. I’ll consider adding an option for this when the beta becomes stable.
Thanks anyway!
Looking forward to more functions!
