(1) I added originally filter (.*)((\.lnk)|(\.sln)|(\.bat)|(\.url))$ to priorities with High status. This seems to do something. For example sln will be show before some other results
Now I’m trying to just experiment, and I don’t think this feature works properly though.
For example, I have now left only and only ahk as high priority, but it still doesn’t end up in the top. See the screenshot:
Could someone give me example how do I add extensions and make the ones I want to appear on top
(2) Seems that Listary doesn’t remember what option I chose last time. For example, if I type 1password and select second item in menu (url extension). It will remember to show it on the top next time, but the moment I restart listary (which happens with each laptop restart), it will again show the normal shortcut in top instead of url
