Alt+Enter:Open containing folder for selected item (And select it, althought select it doesn’t work properly in some file managers, ex:Dopus)
Alt+1:When Listary toolbar is invoked from a non supported app, alt+1 open the selected item(files only) in the active window program (whenever this can be applied).
Hope you consider adding this keys to improve Listary use.
More hotkeys are coming
