Can you please implement a way to rebuild the index via command line or something? I want to put this command inside of a script that automatically rebuilds after I unlock my BitLocker drive, which is shortly after I restart my PC. Bitlocker’s index gets scrambled every reboot and doesn’t function at all, so for now I manually have to rebuild it, being able to script it would be so much better.
Hi, This feature is already available.
Right-click the Listary tray icon and go to Options → Commands. The second item is rebuild.
You can double-press Ctrl to open the launcher, then type rebuild to trigger it.
