In the options where you can add path to favorite folder, a browser for folder appears, could you change it so it immediately shows the input-fields you see below each item but now empty. This makes it easier to paste in path in stead of having to browse for them. Optionally a button “browse” next to the input-field paths.
Is it possible add some sort of support for changing volume drives for favorite folders (paths)?
For example when in options >> menu, you can add favorite folder paths, but now change the drive like this
[a-z]:\test
When listary boots up it will check all paths like this a:\test, b:\test , until the first existing occurrence is met and that folder-path will be included in the menu. The trade off is that only the first occurrence would be placed in the menu. A way to limit the amount of processing time for this action is to use something like this:
[f,g,h]:\test , now only f, g and h are checked for the existence of folder “test”.
Thank you.
