Just got Listary PRO
1° bug
In Favorites options
when a create a Favorite [+ Submenu]
impossible to drag and drop a favorite folder from favorite’s root
directly into the new (empty) Favorite Submenu,
in Config.xml it appears like closed on itself
<Item Name=“Submenu” Type=“Menu”/>
rather than opened like
<Item Name=“Computer” Type=“Menu”>
<Item Name=“Disque local (C:)” Type=“Folder” Path="C:" HotKey=“17155”/>
</Item>
Then I must browse [+ Folder]
and only after the first new folder is added to the new Submenu
I can drag and drop more favorite folder from favorite’s root.
2° bug
In a browsing windows, impossible to add a new Favorite folder
directly into a submenu
only possible [Add here] (favorite’s root)
and after go to Favorites options
to drag and drop the new Favorite folder in Favorite submenu.
Thanks
