Sometimes files I’ve deleted are showing up in Listary during a search.
How do I exclude files in the Recycling Bin from showing up when I do a search?
Try adding $Recycle.BIN folders to the Ignored list in File Search - Priorities.
Sorry. Under which left-hand-side menu item is “File Search”? I’ve been staring at it for 10 minutes and I can’t find it.
Sorry, thought you were using V6. Try Indexes for V5.
I’m sorry, that’s not clear. Do yo mean go to Indexes and add the Recycle Bin folder as a folder to exclude?
Yes.
