on Listary 5, I could hit ESC to focus on the save dialog and then hit enter to save the file.
On Listary 6 that doesn’t work anymore.
It would be even better if I could use some shortcut while focused in Listary (eg Shift+Enter or Enter when Listary box is empty) to save a file on the save file dialog.
Not sure if there is another way to do this just using keyboard currently… is there?
