I have just started using Listery and thought you should be able to drag and drop files, shortcuts to applications etc from Explorer into the Menus Favorites box in Listery Options.
Is there any was to do this?
Thanks, Roger
Thanks, Roger
Just double-click on any empty space in Explorer to activate the popup menu, and select “Add Here”.
