as described in title, when kmonad or kanata running, listary can’t trigger searching window.
I test other key like double click alt to trigger wecom, it worked.
so I guess is it that the method how listary capture key input not proper?
A strange assumption, why do you think the error is in Listary ?
It can be also in kmonad or kanata.
because I tested it.
with double clicking every key except ctrl, it works, how ever it doesn’t when double clicking ctrl to trigger listary. and I make not key bindings on Ctrl.
here is the debug log info When I tested. Ctrl key press and release recognized like other keys.
2023-12-04T09:36:47.996599+08:00 [INFO] kanata v1.4.0 starting
2023-12-04T09:36:47.9968104+08:00 [INFO] using LLHOOK+SendInput for keyboard IO
2023-12-04T09:36:47.9973564+08:00 [INFO] process unmapped keys: true
2023-12-04T09:36:47.9975918+08:00 [INFO] NOTE: kanata was compiled to never allow cmd
2023-12-04T09:36:47.9977431+08:00 [DEBUG] (1) kanata_parser::cfg::alloc: freeing allocations of length 0
2023-12-04T09:36:47.9991556+08:00 [INFO] config parsed
2023-12-04T09:36:47.9992046+08:00 [INFO] Asking Windows to improve timer precision
2023-12-04T09:36:47.9992506+08:00 [INFO] Asking Windows to increase process priority
2023-12-04T09:36:47.9993304+08:00 [INFO] Sleeping for 2s. Please release all keys and don’t press additional ones.
2023-12-04T09:36:49.9995556+08:00 [INFO] entering the processing loop
2023-12-04T09:36:50.0000041+08:00 [INFO] Init: catching only releases and sending immediately
2023-12-04T09:36:50.8853476+08:00 [INFO] Starting kanata proper
2023-12-04T09:36:50.8855538+08:00 [TRACE] (2) kanata::kanata: [src\kanata\mod.rs:1418] blocking on channel
2023-12-04T09:36:54.3171573+08:00 [TRACE] (1) kanata::oskbd::windows::llhook: [src\oskbd\windows\llhook.rs:115] 0, 260, false
2023-12-04T09:36:54.3173753+08:00 [DEBUG] (1) kanata::kanata::windows::llhook: event loop: KeyEvent { code: KEY_LEFTALT, value: Press }
2023-12-04T09:36:54.3178531+08:00 [DEBUG] (2) kanata::kanata: process recv ev KeyEvent { code: KEY_LEFTALT, value: Press }
2023-12-04T09:36:54.3180349+08:00 [TRACE] (2) kanata::kanata: [src\kanata\mod.rs:596] []
2023-12-04T09:36:54.3182138+08:00 [TRACE] (2) kanata::kanata: [src\kanata\mod.rs:609] [LAlt]
2023-12-04T09:36:54.3183906+08:00 [DEBUG] (2) kanata::kanata: key press LAlt
2023-12-04T09:36:54.3186138+08:00 [TRACE] (1) kanata::oskbd::windows::llhook: [src\oskbd\windows\llhook.rs:115] 0, 260, true
2023-12-04T09:36:54.3191295+08:00 [TRACE] (2) kanata::kanata: [src\kanata\mod.rs:1418] blocking on channel
2023-12-04T09:36:54.4081794+08:00 [TRACE] (1) kanata::oskbd::windows::llhook: [src\oskbd\windows\llhook.rs:115] 0, 257, false
2023-12-04T09:36:54.4083708+08:00 [DEBUG] (1) kanata::kanata::windows::llhook: event loop: KeyEvent { code: KEY_LEFTALT, value: Release }
2023-12-04T09:36:54.4094242+08:00 [DEBUG] (2) kanata::kanata: process recv ev KeyEvent { code: KEY_LEFTALT, value: Release }
2023-12-04T09:36:54.4095958+08:00 [TRACE] (2) kanata::kanata: [src\kanata\mod.rs:596] [LAlt]
2023-12-04T09:36:54.4097802+08:00 [DEBUG] (2) kanata::kanata: key release LAlt
2023-12-04T09:36:54.4099916+08:00 [TRACE] (1) kanata::oskbd::windows::llhook: [src\oskbd\windows\llhook.rs:115] 0, 257, true
2023-12-04T09:36:54.4105205+08:00 [TRACE] (2) kanata::kanata: [src\kanata\mod.rs:609] []
2023-12-04T09:36:54.4106598+08:00 [TRACE] (2) kanata::kanata: [src\kanata\mod.rs:1418] blocking on channel
2023-12-04T09:36:54.5501521+08:00 [TRACE] (1) kanata::oskbd::windows::llhook: [src\oskbd\windows\llhook.rs:115] 0, 260, false
2023-12-04T09:36:54.5503299+08:00 [DEBUG] (1) kanata::kanata::windows::llhook: event loop: KeyEvent { code: KEY_LEFTALT, value: Press }
2023-12-04T09:36:54.5514574+08:00 [DEBUG] (2) kanata::kanata: process recv ev KeyEvent { code: KEY_LEFTALT, value: Press }
2023-12-04T09:36:54.5516135+08:00 [TRACE] (2) kanata::kanata: [src\kanata\mod.rs:596] []
2023-12-04T09:36:54.5517957+08:00 [TRACE] (2) kanata::kanata: [src\kanata\mod.rs:609] [LAlt]
2023-12-04T09:36:54.5519774+08:00 [DEBUG] (2) kanata::kanata: key press LAlt
2023-12-04T09:36:54.5521579+08:00 [TRACE] (1) kanata::oskbd::windows::llhook: [src\oskbd\windows\llhook.rs:115] 0, 260, true
2023-12-04T09:36:54.5527941+08:00 [TRACE] (2) kanata::kanata: [src\kanata\mod.rs:1418] blocking on channel
2023-12-04T09:36:54.647089+08:00 [TRACE] (1) kanata::oskbd::windows::llhook: [src\oskbd\windows\llhook.rs:115] 0, 257, false
2023-12-04T09:36:54.6472898+08:00 [DEBUG] (1) kanata::kanata::windows::llhook: event loop: KeyEvent { code: KEY_LEFTALT, value: Release }
2023-12-04T09:36:54.6477207+08:00 [DEBUG] (2) kanata::kanata: process recv ev KeyEvent { code: KEY_LEFTALT, value: Release }
2023-12-04T09:36:54.6479027+08:00 [TRACE] (2) kanata::kanata: [src\kanata\mod.rs:596] [LAlt]
2023-12-04T09:36:54.6480679+08:00 [DEBUG] (2) kanata::kanata: key release LAlt
2023-12-04T09:36:54.6482134+08:00 [TRACE] (1) kanata::oskbd::windows::llhook: [src\oskbd\windows\llhook.rs:115] 0, 257, true
2023-12-04T09:36:54.648856+08:00 [TRACE] (2) kanata::kanata: [src\kanata\mod.rs:609] []
2023-12-04T09:36:54.6489481+08:00 [TRACE] (2) kanata::kanata: [src\kanata\mod.rs:1418] blocking on channel
2023-12-04T09:36:58.2741858+08:00 [TRACE] (1) kanata::oskbd::windows::llhook: [src\oskbd\windows\llhook.rs:115] 0, 256, false
2023-12-04T09:36:58.2744097+08:00 [DEBUG] (1) kanata::kanata::windows::llhook: event loop: KeyEvent { code: KEY_LEFTCTRL, value: Press }
2023-12-04T09:36:58.2752403+08:00 [DEBUG] (2) kanata::kanata: process recv ev KeyEvent { code: KEY_LEFTCTRL, value: Press }
2023-12-04T09:36:58.2754445+08:00 [TRACE] (2) kanata::kanata: [src\kanata\mod.rs:596] []
2023-12-04T09:36:58.2756203+08:00 [TRACE] (2) kanata::kanata: [src\kanata\mod.rs:609] [LCtrl]
2023-12-04T09:36:58.2757979+08:00 [DEBUG] (2) kanata::kanata: key press LCtrl
2023-12-04T09:36:58.275947+08:00 [TRACE] (1) kanata::oskbd::windows::llhook: [src\oskbd\windows\llhook.rs:115] 0, 256, true
2023-12-04T09:36:58.2765319+08:00 [TRACE] (2) kanata::kanata: [src\kanata\mod.rs:1418] blocking on channel
2023-12-04T09:36:58.3731821+08:00 [TRACE] (1) kanata::oskbd::windows::llhook: [src\oskbd\windows\llhook.rs:115] 0, 257, false
2023-12-04T09:36:58.3733988+08:00 [DEBUG] (1) kanata::kanata::windows::llhook: event loop: KeyEvent { code: KEY_LEFTCTRL, value: Release }
2023-12-04T09:36:58.3743857+08:00 [DEBUG] (2) kanata::kanata: process recv ev KeyEvent { code: KEY_LEFTCTRL, value: Release }
2023-12-04T09:36:58.3745698+08:00 [TRACE] (2) kanata::kanata: [src\kanata\mod.rs:596] [LCtrl]
2023-12-04T09:36:58.3747488+08:00 [DEBUG] (2) kanata::kanata: key release LCtrl
2023-12-04T09:36:58.3749677+08:00 [TRACE] (1) kanata::oskbd::windows::llhook: [src\oskbd\windows\llhook.rs:115] 0, 257, true
2023-12-04T09:36:58.3756391+08:00 [TRACE] (2) kanata::kanata: [src\kanata\mod.rs:609] []
2023-12-04T09:36:58.3757567+08:00 [TRACE] (2) kanata::kanata: [src\kanata\mod.rs:596] []
2023-12-04T09:36:58.3758905+08:00 [TRACE] (2) kanata::kanata: [src\kanata\mod.rs:609] []
2023-12-04T09:36:58.3759807+08:00 [TRACE] (2) kanata::kanata: [src\kanata\mod.rs:1418] blocking on channel
2023-12-04T09:36:58.4840933+08:00 [TRACE] (1) kanata::oskbd::windows::llhook: [src\oskbd\windows\llhook.rs:115] 0, 256, false
2023-12-04T09:36:58.4842898+08:00 [DEBUG] (1) kanata::kanata::windows::llhook: event loop: KeyEvent { code: KEY_LEFTCTRL, value: Press }
2023-12-04T09:36:58.485392+08:00 [DEBUG] (2) kanata::kanata: process recv ev KeyEvent { code: KEY_LEFTCTRL, value: Press }
2023-12-04T09:36:58.4856346+08:00 [TRACE] (2) kanata::kanata: [src\kanata\mod.rs:596] []
2023-12-04T09:36:58.4858894+08:00 [TRACE] (2) kanata::kanata: [src\kanata\mod.rs:609] [LCtrl]
2023-12-04T09:36:58.4861137+08:00 [DEBUG] (2) kanata::kanata: key press LCtrl
2023-12-04T09:36:58.4867995+08:00 [TRACE] (1) kanata::oskbd::windows::llhook: [src\oskbd\windows\llhook.rs:115] 0, 256, true
2023-12-04T09:36:58.4885667+08:00 [TRACE] (2) kanata::kanata: [src\kanata\mod.rs:1418] blocking on channel
2023-12-04T09:36:58.5731863+08:00 [TRACE] (1) kanata::oskbd::windows::llhook: [src\oskbd\windows\llhook.rs:115] 0, 257, false
2023-12-04T09:36:58.5734387+08:00 [DEBUG] (1) kanata::kanata::windows::llhook: event loop: KeyEvent { code: KEY_LEFTCTRL, value: Release }
2023-12-04T09:36:58.5741879+08:00 [DEBUG] (2) kanata::kanata: process recv ev KeyEvent { code: KEY_LEFTCTRL, value: Release }
2023-12-04T09:36:58.5743996+08:00 [TRACE] (2) kanata::kanata: [src\kanata\mod.rs:596] [LCtrl]
2023-12-04T09:36:58.5746027+08:00 [DEBUG] (2) kanata::kanata: key release LCtrl
2023-12-04T09:36:58.5748586+08:00 [TRACE] (1) kanata::oskbd::windows::llhook: [src\oskbd\windows\llhook.rs:115] 0, 257, true
2023-12-04T09:36:58.5755292+08:00 [TRACE] (2) kanata::kanata: [src\kanata\mod.rs:609] []
2023-12-04T09:36:58.5757791+08:00 [TRACE] (2) kanata::kanata: [src\kanata\mod.rs:1418] blocking on channel
