I presently used Listary on my Netbook (XP-SP3) for few months now and since a couple of days I’m unable to access the pop-menu by double-clicking on an empty part of the Desktop. I first tried to reintall (the set-up release) and secondly downloaded the last release. But unfortunately, theese two tries didn’t solve the problem.
Lastly, I saved the config.xml before deleting it and relaunch Listary top see if I recovered that fonction: with a brand new config.xml, the double-click opens the pop-menu!
So, it 's probably due to an element in the config.ml I previouly used. As I don’t want to loose all my favorites I would know where in my config.xml I can look to solve this problem…
Thanks a lot for any help,
