Context Menu Question
After I type a couple letters so the list menu pops up, I would like to be able to right click on the file or folder instead of having to use the right arrow key. When I right click on the folder, it opens the folder instead of the context menu for the folder. When I right click on a file, it opens the file instead of opening the context menu.
I’ll add a similar feature which can open the folder directly (maybe a hotkey, for I don’t like mixing keyboard and mouse).
