Clover 2.0.165.0 - Not working correctly (with Listary)
I’ve just installed Clover (2.0.165.0) on Win 7 x64 SP1 German and I’m using Listary (Pro) v1029a (beta).
I open clover and I’m in my libraries folder by default.
I’ve 6 libraries:
Bilder
Dokumente
Downloads
Musik
Tools
Videos
The only item that get’s recognized by Listary is “Dokumente” (or a subpart of it). When I type e.g. “mu” for “Musik” I only get a spinning blue quarter of a circle underneath Listary’s searchbox. The same for all other libraries (except “Dokumente”)…
Do you need any more infos Channing?
It seems that Clover support only works sometimes. I just removed it from the change log and I’m looking into this issue.
Hi Channing, same thing here. Testing the latest version of clover and the search won’t work. I t can only find drives or by default the documents folder.
If you click on a drive to search, it just keeps running without finding any hits.
It works fine in explorer without clover. So, must be a compatibility issue.
Update to clover 2.0216 and everything works just fine.
