Does anyone else have a problem using Listary 5.00.2843 with Chrome 71.0.3578.62?
The “find as you type” does not work in the Save As dialog. Listary does not appear at all.
I have added “C:\Program Files (x86)\Google\Chrome\Application\chrome.exe” to App Settings but it does not help.
Is it possible that your Chrome is running as admin? Does Listary appear on other applications?
Thanks. It appears to be fixed after I uninstalled Chrome, selecting delete history during uninstall and then reinstalling it.
I was not running Chrome as admin and Listary worked fine with other applications so I am not sure what was wrong.
