I go this message when i installed the beta version of Listary
The file C:\Program Files\Listary\is-P94AJ.tmp is infected with Gen:Trojan.Heur.TP.gyY@b86sbdci and was moved to quarantine. It is recommended that you run a System Scan to make sure your system is clean.
This is a false positive, so there’s no need to worry — your system is safe.
The issue is likely caused by our code signing certificate being recently updated. Our previous certificate had expired, and after switching to a new one, some antivirus programs like Bitdefender mistakenly flag the new signature as suspicious.
We’ve already reported this to Bitdefender and are working with them to fix it as soon as possible.
We’ll let you know once Bitdefender updates their definitions to stop the false detection. Thank you for your understanding and support!
We’ve just received confirmation from Bitdefender — they’ve completed their analysis and confirmed that the file is safe. The false positive will be removed in the next 24–48 hours through an antivirus database update.
