It is possible add deeper integration for this popular file manager?
Homepage:
https://www.altap.cz/salamander/features/
It offer copy actual path of selected panel (left or right) and filename (at current position in panel) with keyboard shortcut (Ctrl+Alt+Insert, Alt+Insert).
And also change folder or set focus to particular file in active panel by pressing Ctrl+V, if in clipboard is valid path (“C:\Users\Admin\Documents”) or fullpath (“C:\Users\Admin\Documents\new.txt”)
So that Listary is aware on which folder and file position was activated in Altap Salamander.
Can this be integrated in Listary 6 beta? So instead lauching Explorer or run associated program it only GO TO folder or set position on file in file manager. For example by pressing Enter (configurable).
Thank you.
