Adding UNC path to Favorite
I know how to add a favorite when the location is on my computer but I can’t find a way to specify a path which exists on the network (i.e. locations on the network which start with "\") - also called UNC path names.
I’m using the free installed version (4.23.1728)
Ok, I found two ways to add a UNC path to Favorites.
Option 1: Navigate to the UNC path manually, trigger Listary and select ‘Add Here’ (on the top right hand corner)
Option 2: Add any local folder to your Favorite, then in Listary options go to Menus, select the Favorite you just added and manually change the Path
Perhaps option 2 could be better implemented in future versions of Listary
