I have my C and D drive indexed. I would expect that if I typed in “D:” (without the quotes) into Listary, it would bring up an explorer window at D:. But it doesn’t show as an option in the list. Why not?
Of course it shows a list of results which contain d:
I’m not sure how to make sense of your answer. Perhaps if I provide a screenshot that will help clarify my problem.
I still don’t understand what you mean with “explorer window” as search result.
This will only happen if you select one of the results.
The question for your screen shot is why there is C:\users in the results.
May be you should try a Rebuild index.
I guess you were expecting an item of the path C: in the search result when c: is typed, which is what you get in Listary 5. This is currently missing Listary 6. As a workaround, you can set a filter for each drive to emulate the behavior.
Thank you! Very helpful.
