🎉6.1.0.37 beta released
:wave:Hello Everyone, we are so excited to announce a new update for Listary with several exciting features and improvements.
Download: https://www.listary.com/download/beta/Listary.exe
:partying_face:Main Updates
  • New: Application Integration Plugins
  • New: WinRAR Integration
    • We provide WinRAR integration, based on the open mechanism, and plan to continue increasing the number of integrated applications with the help of the community.
  • New: “How to use Listary” Tutorial
    • We added an interactive tutorial to help users understand Listary’s shortcut keys, search function, and folder Quick Switch feature.
:partying_face:Other Updates
  • Improved: Quick Switch now remains open.
  • Improved: Improve the stability of Ctrl-Ctrl.
  • Fixed: Fix incomplete action list in Options.
I like this new version.
Please add the same buttons (Favorites, History, )as shown in the Quick Switch dialog
to the Pop-up after a Ctrl Ctrl on the desktop or in a file manager
Please add as default ping command.
2023-03-05_18-34-16
I agree with this request/suggestion, I thought that I had somehow messed up installing the latest version or had some software conflict when I saw that this was missing when invoking listary in XYplorer.
Thanks! Do I understand correctly that someone would have to write a plugin to make SpeedCommander integration possible again?
Try to add SpeedCommander.exe to the Features / Integration settings.
Or you can try to press CTRL CTRL while in a SpeedCommander windows.
May be Listary will ask you if support should be added.
I had already tried that, but nothing happens. Ctrl Ctrl results in the normal “global” search box, and clicking a SC window does not change the current directory of an “Open File” dialog, either (like it does with an Explorer window, and as it used to do in the previous Listary version).
