Please ignore for now…I may have solved the problem.
Hello, I recently upgraded to the 5.00.2410 Beta (had been running 5.00.2406 for quite a while without problems). I am now unable to get Listary to open folders within Directory Opus 11.19 x64. If I close DOPUS, Listary will properly open the first folder I try. After that, however, Listary no longer updates my DOPUS window when new folders are highlighted in Listary and Enter is pressed. The Sync feature between the DOPUS and File Dialogs (both the automatic way and the CTRL+G way) are also both broken.
Thanks for any help you can offer.
Craig
