[Resolved] Disable Listary for a specific application not working
Hi, I’m trying to disable Listary for specific applications using this guide : http://www.listary.com/docs/troubleshooting#Disable_Listary_for_an_application
For some reason, the “Commands/Disable Listary for this application” menu entry doesn’t appear in the applications I’m trying to disable (Notepad++ and Kerbal Space Program).
I’ve tried to manually select my application’s executable file and unchecked it, following this guide http://www.listary.com/docs/troubleshooting#8220Disable_Listary_for_This_Application8221_doesn8217t_appear
Nothing works, the Listary menu still shows when I hit CTRL twice.
Am I missing something or is Listary simply unable to disable itself as it should?
Thanks!
Disabling Ctrl x2 in a specific application will be supported soon in Listary 6.
The feature you tried is designed to disable Listary itself in an application, like hiding the search bar on file dialogs.
Oh, I see.
Thank you Channing.
I’m looking forward to version 6 :slight_smile:
