Hello Listary Support,
I’ve bought the Pro version of Listary mainly to replace Filebox Extender.
At first everthing seems to work well, but there is one problem that makes Listary more or less useless for me:
I have defined my Favorite Folders in Menu| Favorites.
If I doubleclick in the explorer Window, everything works fine and the selected folder is opened.
But, if I use doubleclick form a save-As folder (for example Acrobat Reader), the selected folder NOT always opened,
instead the Listary folder is opened most of the time.
And here is my question:
is it possible to define subfolders in Favorite Folders and stop Listary searching for subfolders when
the Favorite Folders are used?
This is how “Filebox Extender” works.
I use Win7-64 Bit and the Pro version of Listary.
Best Regards Siegfried
