###Download link
###Change log
- New: Directory Opus 11 support
- New: FlashFXP support (temporarily)
- New: Ctrl+Backspace support
- Improved: Launch apps performance improvements
- Improved: Left arrow key handling
- Fixed: many bug and crash fixes
###Download link
###Change log
This topic is now pinned. It will appear at the top of its category until it is either unpinned by a moderator, or the Clear Pin button is pressed.
Have to report an error.
When you press the left arrow key too many times listary will crash!
I noticed the following issues in the previous beta version and found it with the current one as well. Listary does not function/pop-up on the “Select File to Insert” or the “Save As” dialog windows. If there is a setting/option that I’ve overlooked to enable Listary on the dialog windows, please point me in the right direction. I’m running Listary Beta 4.20.1539 on Win 8 Pro 32 Bit.
Can you provide the detailed steps to reproduce this bug? I can’t reproduce it here.
It seems to be fixed. I did this after i installed the latest version but i didn’t restart the system. I got a crash report and listary asked me to send it in.
It won’t crash anymore now i restarted the system.
Yes it does! For me at least on a windows 8.1 machine using the portable version.
英语更新说明不太明白,更新了什么了。
发现bug了,和上一版差不多,只是一提没有说,都是软件自动收集后发送了。这次说明一下。
刚才我右方向动作上下移动n次,然后再继续右方向键很多次,再用左键很多次,就会出现卡死自动报错发送。。
我刚刚也崩溃了一次(没怎么注意,应该是在进入动作菜单时,也不知道怎么重现),日志已经发送了,不知能否帮到。
补充下,是在 启动程序 模式下搜索进行的
D011 seems to work great once again, thanks!
除了上次提到的本版左右方向键反复多次后卖到的bug,一直比较好用,好像没有动作菜单消失问题了。相对,搜索列表、动作菜单 反应也比以前快了。
Sorry it took me a while to get back to you. Using Notepad, Listary works under the Save As and Open dialog windows. Also, I’m unable to insert any applications under the Options-By Application in Listary itself.
So what is the application that Listary doesn’t work with? Is it running as administrator?
1533已经更新了,确实体验不错,有时候就是随便试用几下就行了。我前段里由程序出错自动发了好多报告,不知道收到了吗,和我的提交的bug报告有关系 否。呵呵。
目前没有闪消问题了,动作菜单左右键也不会卡死报bug了。。不错,不错。。
希望一下个添加以下功能:
1、就是支持收藏夹网址关键字打开,支持将剪切板的网址快捷建立到此程序下的收藏夹并可加入关键字,可通过 输入web fc 回车 就用默认浏览器打开 www.facebook.com网站,其中 web产前缀,fc是这个网址的关键字。同时也支持快速建立。
2、对自定义命令可以再丰富化一下,之前也提到过。。比如支持多个参数变量的。
3、支持插件,之前有人提到过一个计算器功能的插件。。
很是期待。。目前的版本感觉不错,好久没有提到开发新功能了。
1533发现的一个的小问题,,没注意之前的版本。。就是,按ctrl之后,用backspace键不能删除关键字了,只能再按ctrl键后才能删除。
Just a few questions or suggestion for the forum here, please?
4.20.1553
New: Search path
"Search Path
Add a trailing \ to a keyword to indicate that it’s part of the path."
Example: If you want to search notepad.exe in Windows folder, you can type win\note or win\ note or note win.
While the Search Path has the link with the explanation, none of the rest of the list have any details
[> New: Launch applications (use hotkey Win + S or Win + G to switch between Launch Apps and normal mode)
New: Full NTFS hard link support
Improved: Performance improvements
Improved: Listary Options layout
Improved: No more flickers when showing search results
Fixed: many bug and crash fixes][1]
[1]: http://www.listary.com/download
For example, I’d love to know more about what the DirOpus support, Ctrl+Backspace support, and Options Layout mean, just as an example!
Thanks so much for such an awesome program!! I just want to learn more about its uses, and the older videos you have definitely don’t go into the detail and current feature-list that I would love to see
Leea
Thanks for your suggestions!
I’ve just created a topic for v1553, and will do this for all future versions. Listary 4.20.1553
Definitely. I’ll write a complete documentation for Listary.
Thank you! It’ll definitely help me a lot as I use FAQ and Help documentation frequently for those “indispensable” programs I use all the time – including, of course, Listary!!
