I have a notebook with SSD. Is it safe to use Listary on it?
I disabled Windows Search indexer to avoid continuously writings on SSD. Will Listary do the same?
How does it handle file indexing?
Thanks
It’s absolutely safe to use Listary on an SSD. When you make file changes in Windows, Windows notifies Listary and Listary updates the index accordingly. So there is no need for Listary to read your SSD for indexing.
Also Listary only writes the index to your SSD when you close your computer.
Thanks for the answer
Do you mean that Listary stores index changes in RAM and saves it on shutdown?
You got it.
