Is it possible/necessary to "Unregister" a machine if I want to install it on another?
#1
Hey,
I am currently using listary Pro on 3 machines, but would like to change which machines I am using it at. Is it possible to return 2 of my installations to Listary Free instalations so I can upgrade 2 other machines to Pro? Or is uninstalling enough?
#2
Uninstalling is enough. You don’t need to deactivate it manually.
#3
Awesome, Thanks for the quick answer
