I’m user of Directory Opus.
When typing “Dir” appears first an app called “Dinero”.
Sometimes I forget about it and after typing Dir I press ENTER launching Dinero.
Can I delete “Dinero” from first result?
Thanks,
Thanks,
First make sure you’re using the latest version v5.00.2410, there is a related fix: http://www.listary.com/download
Then if you type “dir” to launch DOpus a few more times, DOpus should always be the top one. If it still doesn’t work, please reply here.
Perfect
Thanks!
