- Meta-searching - please please and pretty pretty please add this feature. Only Alfred (Mac) and FindandRunRobot (PC) have it, so I beg you to consider and apply it.
For example, if I type in zz it will send the keywords to Amazon, Fakespot, ReviewMeta and other sites. If I type m it sends it to Google search, Rotten Tomatoes, IMDB, etc…
Currently, one has to do each of these manually. This is a very powerful feature and saves the user so much time from having to re-launch Listary and searching several other times. This is the only feature I am absolutely dying to have. You could allow the user to add additional (as many as user wants) URLs to entries in the Keywords/Web interface.
For example:
Keyword: m
Display Title: Meta Search in Movies for '{query}'
URL: http://www.rottentomatoes.com/search/?search={query}
URL: http://www.imdb.com/find?s=all&q={query}
URL: etc etc…
typing m top gun would open 3 windows in browser and send the query to all 3.
Can this be done?
Allow the user to delete default ANYTHING in the program. Some you can modify, but It’s a pain to modify the existing ones and the ones you can’t clutter up the interface.
Allow manual reordering of items in all windows (via dragging) (especially keywords window). Allow also for sorting by clicking on the column.
Add a note to Appearance / Options page that the size DOES NOT affect the applauncher window (only the find as you type window). This is very confusing behavior the way it’s currently implemented.
