Copy path of saved file
Can Listary copy the path string of the file that is being saved? I want to have the file path in the clipboard after it gets saved. This way I can paste the location somewhere else that needs it. Thanks
Unfortunately Listary doesn’t support this feature. It’s also tricky to add it because the new file doesn’t exist when Listary is active (the save file dialog is open) and there is no reliable way to get the saved path.
