Listary is an exciting product and with version 5 almost here with new versions in the mix it only gets better.
As it is Listary is very exhaustive in it’s search function and it would be awesome to see Listary support monitoring of the clipboard so that you could search through all the items that you have copied into it.
A bonus would be to identify where the copy came from; a copy concerning pasta types from Opera would have an Opera icon(or text) indicating the same. This would be very useful in retrieving information you did not paste and would like to recover from the clipboard(except in this case you would be searching the index created from the clipboard contents)
I hope you consider this feature for version 5 and keep up the great work
