What is (and potentialy how to disable) a `Go to` section
So I have a folder called Common and each time when I try to select it by typing com this happens: ImageShack - Best place for all of your image hosting and image sharing needs
Selecting these Go to entries does nothing and they don’t let me get into Common folder easily.
Please use the latest version: listary.com/download
You can also try Listary 4 beta here: discussions.listary.com/discussion/157
Thanks a lot! Latest Listary stable version has solved this :slight_smile:
