Hi. I’m trying to use the {custom_folder} variable in a custom Keywords parameter but it’s returning a blank value.
I’ve tested as follows:
- create DOS batch file which runs
echo %1
and pauses - create custom Keywords action to run the batch file with {current_folder} as a Parameter
- run the Keyword
The console output indicated that nothing was passed. The variable is clearly defined because if I try any other value, e.g. {current_path}, just in case your tool-tip is wrong, the echo is the full text.
The {query} parameter works fine.
I know you’re working on v6 but I noticed you mentioned performance issues in the beta so I’d prefer to wait a bit.
Thanks
