Transfer settings from portable to installed version
I’ve been using the portable version of Listary for a while. Had originally installed it as a portable version when beta testing for version 4 and had just updated the portable version as new updates came out. Now I installed the newest update (instead of the portable) but obviously it doesn’t have my settings and favorites.
This is all on the same computer, so I would like to transfer these settings if possible. Is there a way to transfer my settings and favorites from the portable version to the installed version?
Thanks.
  1. Exit Listary.
  2. Copy UserData folder from the portable version to C:\Users\<Your User Name>\AppData\Roaming\Listary\UserData
Thanks. Worked great.
Just for my information, is there any advantage to running the installed version vs running as portable?
Thanks.
Hi, there is no difference.
