The List 5 used to remember the order of results. If I select something, that result becomes of higher priority.
See attached image. The “Slack Erinc” is the second result. If I select it, and later search again it will be the first.
However, once the laptop is restarted (or Listary.Service process is killed), it forgets about this. Interestingly, just exiting Listary and starting again, doesn’t cause this issue.
