Selected search result entered as string?
There are times (i.e. if a program asks me to enter a path to a folder or .exe) when I want to use Listary to do a search, and then enter the result into a text field. Most recent was when I needed to enter the full path to the Chrome folder, so I did a search for “Chrome”, chrome.exe came up, then I wanted to be able to click it so that it entered the path into the text field, but the only (apparent) option was to launch Chrome when it was clicked (or enter pressed), even if I tried right-clicking it.
Is there some way to enter any result as the actual string path? Maybe a right click option or something?
Thanks
Press right arrow key instead of Enter against a result, and then select “Copy Path to Clipboard”.
aha! Cool! thanks.
