使用路径匹配符的时候,在搜到的项目上无法使用右方向键进入操作界面啊,老大
Regarding the wrong working dir of batch files, please see the screenshot
这个有点奇怪啊,使用路径搜索返回的结果类型与普通搜索并没有任何不同。
Thanks for the information. I’ll test it.
This topic is now pinned. It will appear at the top of its category until it is either unpinned by a moderator, or the Clear Pin button is pressed.
@Channing: Shortcuts can’t set ctrl+ctrl it’s so easy way to search 快捷键能设置成 ctrl+ctrl 吗? 这种很方便,但是不支持.
@zhenglongqi 曾经考虑过,但是太容易冲突了。
@Channing
I’m using Lauchy with Windows + A and Listary with Windows + S. If I want to activate the Launch Apps mode of Listary I have to press Windows + S twice. It would be great to have an extra shortcut to trigger Launch Apps mode directly e.g. with Windows + A. So I could replace Launchy.
Additionally it would be nice if Listary would remember the last input as Launchy does. Sometimes I call repetitive batch files via Launchy and all I have to do is to press Windows + A and then Enter. With Listary I have to type the name of the batch file again.
@martin Listary should remember the last mode. The second time you press Win + S Listary will work in Launch Apps mode directly.
Searching history is definitely something I should work on. It will be added
Thanks for your hard work, awesome improvements.
Would it be possible to make it also match when search words contain spaces.
Example: [link][1]
[1]: http://hezer.naraku.org/stuff/images/ListarySearch.png
Try world\of\tanks\modpa. Any word ends with \ is considered part of the path. You can also type modpa world\tank\
Ok, that works, didn’t try to do it like that.
Looks like a search path + fuzzy search bug:
File’s path:
%temp%\fe5bdf\general\10_sys_sync_grants.sql
Trying to find it in Listary:
“temp\fe\10” - works well, the file is shown.
“temp\fe\10gra” - doesn’t work, the file is not found by Listary
