Search and consider "_" and "-" like a space
hello,
how setup listary to search and consider “_” and “-” like a space ?
thank you
Hi, this is not supported. Could you give a real-life example of the usage of this feature?
I will exactly give you an example to better understand the problem,
often I have files and folders that they have been named in the following way:
folder A
folder B
file C
file D
folder_1
folder-2
file_3
file-4
with listary software, when I start typing a beginning of the word to do a search with
“folder …”
here only “folder A” and “folder B” appear in the search result
"file "
here only “file C” and “file D” appear in the search result
it’s better that the listary software can take into account that a space " " is can equivalent to “-” or “_”
thanks
Hi, Listary can find “folder_1” and “folder-1” if you type “folder 1”. Just give it a try.
