I am using listary pro 5.00.2381
Whenever I search for a file, then open the right-click context menu to copy and paste a file, listary hangs and takes at least 30 seconds to recover
I have updated to the current beta version however the problem was there even in the regular version
The OS is Windows 10 Pro x64
If you right click directly on the same file in Explorer, does the context menu hang?
I did not see that…wow it does
It’s likely to be caused by a 3rd-party context menu extension. You may want to check that.
