Prefix to disable the current list temporarily in Directory opus will be auto to enabled
I use listary with directory opus.
In directory, sometimes i need to disable listary, i set the prefix as /
when i type /, listary will be disable as expected.
but, listary will auto enabled
in default windows explorer, it works well.
when i type /, listary will be also be disabled as expected.
it will keep disabled until i type ESC
listary version: 4.02.1360
This is by design. Most users only want to disable Listary’s find-as-you-type occasionally, and they need it to restore automatically.
