Opening folder
  1. Click on taskbar
  2. Win+S
  3. Type eg. “Windows”
  4. Hit enter on C:\Windows folder
Default Directory Opus lister is opened, instead of C:\Windows
Version 4.01.1175
Check your default file manager setting:
Imgur
This is it.
The “parameter” field was empty.
I am using Total Commander, may I ask this, if there is already an instance of TC running, if I “4.Hit enter on C:\Windows folder” as daroc did. Can Listary change current path of active TC panel (the copy of running TC) instead of launching a new copy of TC?
I assume %1 will be replaced by Listary with the selected path, but can I prefix something or append something to it, I mean something like:
/<switch1> %1 /<switch2>
@tslim
Check this link.
