Multi monitor support
middle click on the desktop brings up the Listary window, selecting a folder from the list opens Explorer window
question:
currently on a multi monitor setup the explorer window always appear on the first monitor, even if you bring up Listary on a second or third one. would it be possible to alter this functionality so the Explorer window would always appear on the desktop that was currently selected?
Hello Marek,
The position of a new Explorer window is controlled by Windows itself, and it should be always on the same monitor as your last closed Explorer. Sorry that there isn’t much we can do here.
fair enough, but wouldn’t it be possible to catch that data and interfere with it?
That’s possible, but needs lots of extra work. I’ve added it to my plan with a low priority.
marek, you can switch/move the panel to another monitor via “shift+ windows + left or right arrow”
