Monitor last opened folder of FreeCommander
Hi!
I’d like to use Listary along with FreeCommander.
“Find as you type” and setting FreeCommander as the default file manager in Listary works, but I can’t get it to monitor FreeCommander’s last opened folders. Also opening a folder from the Listary context menu in FreeCommander (e.g. Recent > [Folder]) does not seem to work - nothing happens.
Tried Listary 4 Beta and FreCommander 2009/XE.
Any ideas? Thanks!
I haven’t tested the beta with FreeCommander yet. I’ll look into the issue.
